Low Power after hitting a bump
beav626
Pretty Girls in your city for night
Usa
Cruising down the highway yesterday 60mph on cruise control. I hit a expansion joint and it jolted me and the truck.
immediately I lost radio and doors unlocked and AC quit.
Radio came back on quickly and I locked the doors. Thats when I realized I was blowing hot air (no AC)
I took my exit and as I slowed I felt like I lost Power Steering.
I parked the truck and turned her off. Started her up and she started fine but idle seemed lower than normal. So I went in the store and came back out. When going slow if I turn the wheel my idle drops too low and kicks off my AC.
Got her home. Checked the Freon level- Its Good.
Checked the idle with HPTuners and it is 550 which is what the tune called for.
Disconnected battery and let the truck sit for an hour.
The air-filter is dirty so Im going to replace that.
Still having a problem when turning at low RPM's it dips to low to keep the AC on.
No Lights or leaks... Checked O2 sensors through HP Tuners and they are performing normal.
No Mods except for Flowmaster Exhaust and a tune.
2003 Escalade 6.0
What the heck happened.
Ant ideas are helpful.
B
beav626
Usa
All belts are on and seem OK...
I drove around today after posting and AC worked fine. Idle stayed up except for a few times at a turn in a parking lot or two the idle dropped very low while turning.
Could this be Power Steering related or maybe a ground somewhere?
bkboatnsleds
McHenry, IL
sounds more PS related to me...not to sound dumb.. Take the serpentine belt off and make sure the PS pump pully / shaft is not broken.. I have seen it happen - however I'd think you would not have ANY PS if this was the case..
---------- Post added at 09:33 PM ---------- Previous post was at 09:33 PM ----------
although I forgot about your electrical issue... thats weird, is that acting up at all since?
B
beav626
Usa
only once after the bump... Cruising home I was on a smooth piece of road and my doors unlocked and AC compressor kicked off.
I re locked and turned the AC off and back on. and it hasn't happened since.
B
beav626
Usa
Ok- I keep getting the random Power reset while driving. I am almost 99% sure it is a loose ground somewhere. Do you have a diagram showing where the grounds are on a 2003 truck?
bkboatnsleds
McHenry, IL
I don't have a diagram.. but I remember from doing my motor swap most of the grounds were on the back of the motor against the firewall up top.. I think mostly on the driver side. May be hard to reach with the intake on.. but if you feel back there for some broken wires you'd at least know. I'd guess if it broke the terminal end weakened and the wire snapped off that..
B
beav626
Usa
Thanks- I will get back there.
B
beav626
Usa
All my extended research pointed to the ignition switch. Just pulled that out and will go get a new one in the AM. I will post back results.
Gzes
the drifting 2dr
Wichita tx
Sounds weird never had that problem. How much for the part?
B
beav626
Usa
I didn't get to driver her since I did the install. So I will drive tomorrow and see how she does.
One friend had this go out in his Vette and suggested it might be the cause since the symptoms were similar.
Another kept mentioning that it might be the cause as well. After doing some reading I figured why not.
My fingers are crossed (I hate Electrical Gremlins)
B
beav626
Usa
Fingers crossed didn’t work. Still losing power at bumps. Back to grounds? I checked the fuse block under the hood and it was good. Battery is tight.
Symptoms: Gauge needles get erratic, doors unlock, ac compressor kicks off, Check engine light comes on, cruise control is kicked off (if engaged)
Gzes
the drifting 2dr
Wichita tx
The engine has a ground in the back. Don't know exactly but when I got my engine overhauled, my mechanic showed me the wire and it can easily break and he said it was just hanging so you should look for it and see if it's good
B
beav626
Usa
I can change a water pump, and many other things... But how the Heck do I access the back of one of these motors.
I was under there today. Checked the front ground and it was good. But I couldn't find how to access the back of the motor from the top or underneath.
bkboatnsleds
McHenry, IL
Honestly - its TOUGH with the intake on.. if you can even see it at all.... I'll try to post a pic.
D Rollins
