Lights staying on!
Sssam00
Hello!
Need help! One night all my lights front and rear including reverse lights came on in the middle of the night on its own!
Now I can’t turn them off at all!
Scanned it and no codes came up.
Any help would be awesome!
Sam
StephenPT
St. Helens, OR
Disconnect the negative battery terminal and then reinstall. Make sure both negative and positive battery connections are tight.
S
Sssam00
Yes I’ve done that! Even as far as leaving them off for a whole day. As soon as I connect the battery back the lights all come back on!
StephenPT
St. Helens, OR
Sounds like a BCM issue - you don't really have any other options but to take it to the dealer at this point. It should be covered by warranty as I'm assuming you're on a 21+ SUV.
S
Sssam00
Turned out to be a corroded fuse block and had shorted out the lights!
Had to replace the fuse block under the hood!
HighCountry22
Maybe it’s related to this recall?
  • GM Recall #:
  • N222386380
  • NHTSA #
  • 22V903
  • Date Issued:
  • Dec 08, 2022
Recall Title:
Daytime Running Lights (DRL) May Not Deactivate When Headlamps Are On
Recall Description:
General Motors has decided that certain 2020 – 2023 model year Cadillac CT4 and CT5 vehicles; 2021 – 2023 model year Buick Envision vehicles; and 2022 – 2023 model year Cadillac Escalade and Escalade ESV, Chevrolet Silverado 1500, Suburban, and Tahoe, and GMC Sierra 1500, Yukon, and Yukon XL vehicles, fail to conform, in part, to S7.10.5 of Federal Motor Vehicle Safety Standard (FMVSS) No. 108, “Lamps, reflective devices, and associated equipment.” The daytime running lamps (DRLs) may not deactivate when the headlamps are on, as required by S7.10.5, Table I-a. of FMVSS 108.
Safety Risk Description:
If the DRLs do not deactivate when the headlamps are on, the resulting glare could increase the risk of a crash.
Repair Description:
General Motors will update the software in the vehicles’ Body Control Module (BCM) to correct the condition. Owners who have accepted applicable terms and conditions will have the opportunity to accept these software changes using wireless over-the-air (OTA) technology without having to bring their vehicle to a dealership. Alternatively, owners may have their vehicle serviced at a GM dealer to receive these software updates.
WalleyeMikeIII
Sunny and Snowy Minnesota
  • GM Recall #:
  • N222386380
  • NHTSA #
  • 22V903
  • Date Issued:
  • Dec 08, 2022
Recall Title:
Recall Description:
Repair Description:
No, OP answered in post #5 he had a corroded fuse box.
koomie98
