Leveling front end with rear
sgreen
Spring, Texas
Alright guys, I know you have heard this a million times, but I have searched tons of threads trying to find out best way to do this and there's so much information I feel like I haven't figured out best option so...
What is the best way to level the front end with the back on my currently stock 2003 Tahoe Z71?
With doing this, what is the largest tire I will be able to fit?
Any suggestions on where to buy and what brands are best?
Thanks in advance for your help.
Splatmaster527
Cleveland, OH
Google Tahoe or Yukon Torsion Key leveling kit and you will get more info than you know what to do with...
Grab some ebay or ford keys throw em in and crank em up you will be set to go
You can get up around 32 to 33in with a bit of trimming on the front
WildBill
Ebay Keys of Ford is good enough. dont waste $$ on the expensive ones. be careful cranking them its ******* the CVs. I have 33s with just a touch of rubbing. If you dont wat to trim inner fenders, you can drill small holes in them and zip tie them back. (you dont even see it even up close)
Back spacing and width of the rim is critical. If you do wide tires, check the back for rubbing too. I flipped the top shock mount bolt to Head-out for better clearance.
TallHoe 96 OBS
