LED Exterior Lights
sam123
Tampa
Stick
Canada
Yes, providing they are in fact the correct replacement lamp numbers your ride requires. I have no idea what your owners manual calls for but just double check before buying. The brand itself can be trusted nonetheless. Even if they are over priced, you get what you pay for.
BMPNUGLS
Mid-MO
Thought I would add my recent experience...just upgraded to a 2016 Denali XL on Black Friday from my 2015 Suburban...I installed a HID low beam kit, Philips LED reverse and license plate bulbs in the Suburban and loved them! Very bright and pure white color...
However, as bright as the Philips LEDs were vs the stock halogens they didn't 'project' the light rearward much and created a very 'fuzzy' backup camera image....so I wanted to try something different in the Denali....and ran across these mentioned on the forum and COULD NOT BE HAPPIER!!!
iJDMTOY Extremely Bright 5-CREE 25W High Power 912 921 920 T10/T15 LED Bulbs For Car Backup Reverse Lights, Xenon White https://www.amazon.com/dp/B00CORBQUA/ref=cm_sw_r_cp_api_aEDtyb69B8VGK
These are just as bright as the Philips BUT they have a focused beam directly rearward and provide a MUCH better light for backing in the dark AND the camera image is AMAZING compared to the stock halogen bulbs or the Philips bulbs at night!! SOOOO glad I tried these!! I'll try to get you some night pictures and pics of the backup camera image soon!
05Single
afraid of the dark
Brand new, should have your owner manual. should be a list of exact replacement bulbs and sizes,
For future reference ;)
Slow5.0
Missouri
I didnt take pics with Philips 921 leds but here are some pics with Super Bright Leds 921 10 SMD tower led i was talking about in my previous post
If you take pics of your nav with rear view camera on and compare to mine you will see difference im talking about
Slow5.0
Missouri
Those led are almost like one im talking about. These SBL have 10 SMD, 350 lumens and 2yr warranty but they cost double iJDMTOY leds
BMPNUGLS
Mid-MO
Below are shots of the reverse bulbs I bought that I payed the link on Amazon for...the rear pic doesn't really tell u a lot other than they are BRIGHT!! The other two backup cam shots..:eek:ne is in a dimly lit parking lot then the second I took in a completely dark section of the warehouse parking lot...you can see how much the light projects rearward!
ajs800
Michigan
appreciate the pics...I currently have the 921 and while they look super bright, I can't stand the lack of light they project at night with rev cam. I plan to swap out with one of the others right away. thanks!
B Hag
Has anyone updated their headlights or hi beams? I ordered some from superbrightleds.com because they said they would fit the housing but they do not. Need suggestions...
CrackerJack135
