Just broke my rear door locks!? Help pls
thirsty1258
Hello all. After working a very long shift I was dropping my kids off to day care. I began to open the rear door at the exact time I pressed the door lock button on the fob not really thinking.
The door opened slightly but at the same time the door locked. It would not unlock unless I manually pulled the lock up. Now the door lock unlocks and most time won't. Can see it slightly move when I press the button but it won't pop up and if I pull it up and press lock sometimes it goes down most times not. What could I have broken inside ? I'm thinking of pulling the panel off this weekend and taking a look but any ideas.
Sent from my Galaxy Nexus using Tapatalk 2
Modded
That Guy
You probably broke the door lock actuator when you did that. More than likely it will need replacing. The main symptom is the door will not unlock/lock with the remote most of the time. Sometimes it will.
T
thirsty1258
Dang any clue how much they run ?
StevenFromTexas
Mr. Negative
Lubbock, TX
Are those the door lock actuators that come with a ninety-minute or until-you-drive-off-the-dealer's-lot, whichever comes first, warranty? :uhoh2:
roflwaffle
