Installing Sub/Amp this coming Monday...
ChrisAU
Birmingham, AL
Have a few questions.
Where have you guys routed your power wire? I plan on just tapping into the ACC wire behind my AVIC for the remote. I have heard there is a grommet on the drivers side that is easily accessed through the engine bay, is that true?
Also, where did you guys ground your amp? I haven't found any good answers to this one and my thought is simply shooting a couple of self tapping screws through the wire into the floor (below the carpet).
04ctd
Charleston SC
usually ground as close to the Amp as possible.
most folk use a "star" ground, with all the ground wires coming off one bolt, for all the components in that area. supposed to eliminate ground loops & hums
scratch the paint off before you put the bolt in, so it is metal to metal.
ChrisAU
ChrisAU
Birmingham, AL
Yeah I've installed many setups before and I know to go 3 ft max from the amp...I guess I'll just cut a slit in the carpet I can push the wire through, then pull up the carpet, sand a good little spot, and ground it there.
bauer4567
Allentown, PA
Do you have rear captains chairs or bench??? And where about in the truck are you wanting to mount the amp??
ChrisAU
ChrisAU
Birmingham, AL
Rear bench. Leaving the 3rd row in too, found a box that is 13" deep at the bottom, has a back slant that makes the top 10" deep, and the front is flat which I will face to the rear of the Tahoe. I cut up some cardboard to make a replica and made sure it fit fine before I ordered it. And also ordered a grill for the sub just in case, but it will have plenty of room.
I planned on just mounting the amp on top of the box, that way when I needed to haul something, I could pull the fuse under the hood, unhook the power, remote, and ground from the amp, and pull the whole shebang and 3rd row seats out.
briannorris
