Installed Lasfit LS Plus Series H11 LED’s
Michigan
https://www.lasfit.com/products/h11...1ha2UiOiJDaGV2cm9sZXQiLCJtb2RlbCI6IlRhaG9lIn0
I Installed Lasfit LS Plus Series H11 LED’s to replace my stock halogen bulbs in my low beams on my 2018 Tahoe LT
The build quality feels solid without any cheap feel to them.
Installation was very easy, they are a true plug and play, non polarity sensitive. Make sure the led’s are facing the 3 and 9 o’clock with the wire cord facing down at the 6 o’clock position.
They cleared the stock dust covers with no problems unlike some other brands.
Also they did not throw any lights or codes on the dash and did not cause any hyper flash
They give out a perfect beam pattern and cut off and have not noticed any negative reactions for other drivers so I think they are set up perfectly. They are 360 degree adjustable as well
The color matches up perfectly with the oem Day time running light strip. These look like they came from the factory
They make a world of difference in brightness at night and can see much better in rain/snow as well
They made my 8 year old truck look so much more updated. The pictures really don’t do them justice and sorry about the picture quality not being the best due to weather not permitting
I recommend these to anyone wanting to upgrade your halogens and to see better and be seen better
CMoore711
Great comparison pics!
Multiple threads on here with LED bulbs working very well with the K2XX low beam projectors.
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
I’ve used those on a couple of my rides. Great stuff.
Tahoecrewcar
Very helpful post @Michigan. I have a 2019 Z71 Midnight that has the stock halogen light setup. It's always frustrated me how awful the low beams are. I've been wondering about changing to LED lows for a while and your post inspired me to give the LASFits LSPlus series a try. I already use their license plate and reverse LED lights which look great, so these new headlights should look just as good.
I see your post is about 3 months old. How are the lights holding up and performing for you now?
LsHart
Senior Member
I like the thickness of the gasket on the bulbs. Looks like a real good seal!
Tahoecrewcar
I did the LASFit LS Plus LED headlight bulb upgrade last week. Incredible difference from the stock halogen bulbs. I did measure and mark where the stock halogen bulbs cut off line was at a distance of 25' in the garage. The LASFit bulbs perfectly position the LED diode at the same distance from the bulb base as the stock halogen bulb does with its filament. This is important as it positions the source of light in the correct position inside the light housing so the optics work as intended. Once I installed the LED bulbs and tested them, the cut off line hit the back wall at exactly the same spot as the stock bulbs (albeit much brighter and at a 6000ºk color temperature vs 3200ºk like the stock halogens). Very happy overall and really enjoy being able to see at night. Also, no oncoming traffic has flashed high beams at me due to the lights being aimed correctly and not "dazzling" other motorists.
CRN_25
