HVAC Control Unit Reset?
I have the manual hvac headunit with the temp sliders. Does anyone know if there's a reset procedure? I bought a Dorman replacement--which initially worked, but now everything is coming out of the defrost. I don't think there is, but I could be wrong.
ks03
Fool Excess Member
I know ive forgotten the auto hvac relearn trick, and don’t think there’s one for manual. However I know you can also pull an hvac fuse on the drivers side of the instrument panel to cause the auto hvac to relearn
Fless
Super Moderator
Elev 5,280
@Tonyrodz has a Tech 2 so he could reset an auto hvac head, if he had one. I don't know if there is a provision in the Tech 2 for manual hvac reset.
EDIT: Tony, can't you command the HVAC head unit with the Tech 2, to see how the various blend doors, etc. respond?
I can def give that a try. Thx guys.
How would you do this @ks03 ? While running--key on?
HeavyChevy45
