How often replace ignition coils?
Rayyy
Northern California
2001 Yukon XL 5.3
I’ve always been under the impression that coil packs are considered good until they fail, with no need to replace otherwise.
Then I read somewhere about coils being needed to be replaced every 100k miles?
(I’m currently at 153k miles with original coil packs).
Does anyone do this? Would I get better MPG and/or performance from fresh coil packs?
(About to do a tune up, so wonderingwhether to also replace the coils packs).
when I had my 00 the originals were still good at 240k, I put in a new motor and when I did that I used all new everything except the intake manifold.
on the old ladys 04 though I got a couple bad ones at around 180k so I replaced them all.
as long as you are not getting any misfires they should be fine the ones from 00/01 are the same and they seemed to hold up pretty good and I was pretty abusive to the vehicle.
if you decide to replace them Herko sells them on ebay and from what I understand they are oem without the oem labels or they are made in the same factory or whatever I have used there coil packs and injectors and never had any problems, prices are good. I put the parts side by side and you could tell they were the same and on the injectors they just removed the oem label so they could re-market them I could see where they had used something to remove the label.
Boz86
2001 Yukon XL 5.3
I'm at 200K, had to replace one around 185k when it started misfiring and throwing a code.
vsaravia
