tRidiot
- Joined
- Dec 21, 2011
- Posts
- 377
- Reaction score
- 293
My '04 Tahoe LT has nearly 300k miles. Replaced the motor with an LQ9 6.0 and had the trans rebuilt just 2 years ago. Oh, wait... ok it's been 3y. But less than 15,000 miles, I think.
I put Bilstein 5100s on in late 2017 when I did a slight lift, probably 30k miles since then. No more than 40k, but whatever. The last 18 months I've started doing a little bit of towing a trailer, but sometimes with a decently heavy load on the trailer. Mostly hauling some wood for the smokers, once hauled 3 large propane tanks (2 250s and a 500) that were empty a few hundred miles. Not heavy-ass boats or anything.
Anyways, it seems a little sloppy, more sway the last year or two. A passenger commented on this and brought it (more) to my attention, he wondered if I had sway bar problems.
Moreso, though, I have lots of squeaking with any kind of bumps. I can't tell when driving if this is coming from front or rear, really. I can't seem to make it squeak from standing on the bumper and bouncing. The squeaking is with any small bumps on anything but the smoothest of roads. I do notice it 'tightens up' and goes away when braking coming down a hill. I don't know if this is because it puts more weight and tension on the front suspension or takes weight OFF the rear suspension. I thought this could have been a wheel bearing that a shop told me needed replaced (driver's front bearing), but after replacement of the wheel hub (Moog 515054) and inner/outer tie rods (Moog ES3488 & Moog ES3493T) in that position, it has remained and continued to worsen.
Most notably, when picking up a couple of ricks of wood a couple of weeks ago, the rear of the truck was REALLY squatted down badly. I was pretty tongue-loaded on the trailer, but it seemed to be a lot worse than I would have expected. Still had the squeaking when loaded and towing.
My question is, what am I looking for to evaluate my shocks from underneath? I can pull it into my friend's shop and get it on stands, but I'm not sure what I am looking for under there that might give me a clue? Worn bushings and that kind of thing ought to be pretty obvious, I'm sure - when I did the shocks in 2017 (again, 30-40k ago?) I did put in a Moog K80631 Stabilizer Bar Link Kit but didn't replace the stabilizer bar. At the same time I also put in Moog 81069 coil springs and did a slight key lift - like maybe 2-3"? So when I'm under there I'll inspect and look for cracking of bushings and things, but I just want to know how I can specifically tell if the shocks are shot, besides leaking fluid, of course. I don't mind replacing the shocks, I've watched some videos and this looks like a relatively easy job, but I hate to spend a couple hundred bucks right now and not end up fixing my problem. Things are extremely tight for us financially at the moment.
Tips?
Tips?
As an Amazon Associate we earn from qualifying purchases.
