Hood skin separation
PenultimateLap
Hello all, just picked up a 03 z71 suburban from a close friend and going through and sorting it out. I noticed the hood interferes with the fender up near the cowl, so I suspected crash damage or hinge damage. Upon closer inspection it appears that the hood skin is separating from the frame at the seam allowing the hood to flare out and lose its shape. Has this happened to anyone else? Almost like the new version of the buckling hood conundrum that plagues squarebody trucks. Thanks.
I've never heard or seen anyone having an issue like that before. Is it an oem hood, or aftermarket? Do you live in a salty state? What exactly does the hood look like where it's separating? Is there any visible rust or any other type of corrosion? Pics would help.
P
PenultimateLap
It's original and I know he babied it which is why I thought it was weird. I'm in sunny CA so there's not a bit of rust. It was too dark for pictures, but I'll grab some tomorrow.
P
PenultimateLap
you can see the folded seam is openning up. Its right at the spot where the hinge force would stress it. Just wondering if it was a known issue at all. Might just be time for a HD swap, ha!
Strange, never seen that before. Looks like the seam sealer/body adhesive just gave up right there. I bet a body guy would have an answer. Does that area flex when opening and closing the hood? Are the hinges really stiff?
P
PenultimateLap
yeah it bends right there. doesn't seem overly stiff. Probably just end up refitting the seam to get it back onto shape and tack weld it back to the inner structure...
Blackcar
I would use panel adhesive first then c clamp with 2x4 on hood surface and smaller peice of metal on seam on bottom and leave it set a day first tack weld as last resort, any more panels are glued together good luck.
Candielaine
