Hids dont match color
Luis6769
Hi my lights don't match color even after swapping new bulbs and ballasts. I tried 35w and 55w ballast and still no matching color, any ideas will be appreciated
what brand are you using?
how are they wired?
try each one separately in just one light housing, if the color is the same then it is either your light housing or you need to rewire the discolored side so it gets better voltage.
if the color is still different when trying them on just one side then time to go with different brand but generally I have found when one side is a different color it is the ballast not putting out the right voltage.
D Rollins
