heater control valve location???
wrx600rr
I am trying to figure out why I dont have heat in my tahoe and have been replacing parts and now I am at the heater control valve but dont know its location, so far I have changed my blend door actuator. I have rear heat but it takes a while to get hot so I figured I will change the heater control valve now so if anyone could point me to its location it would be appreciated! if that doesnt work I am gonna replace the thermostat!
rsb907
Anchorage, AK. By way of SE GA
heater prob??
hey man. im having some heat problems also. when i turn on my heat is doesnt warm up. my rear heat works fine. i changed the cabin filters under passenger side dash but still not blowing warm air. filters were dirty. dont know if it it may be thermostat or heater control valve. did you ever get yours working if so what did you do to fix it?
heater control valve is right by the 2 hoses that lead to your firewall for the heater core. super simple to replace and get too
04YUKON
FLORIDA
There is a sensor in the headliner. Behind what looks like a speaker grill above the dri vers seat. I had mine replaced and the hvac system codes cleared...
hope that helps
skcudog
Where is the "blend door actuator" located? My gf has some heater issues as well. Water temp is fine but sometimes the air goes to cold out of the blue???
johnsonwillie199
