Heated and Cooled Cup Holders
376ci
Canada
Has anyone else installed the Escalade Heated and Cooled Cup Holders in their Denali?
376ci
376ci
Canada
I bought the cupholders on eBay.
After reading all the threads of guys swapping them into their escalades, I figured if they could do it, anyone could.
Boy was I wrong, escalade cup holders and Denali/Yukon/Tahoe cupholders couldn't be any more different. It's far from burning a couple heat steaks off and epoxying it back on.
08grey
Do you have the factory sub. I thought when I looked at it good it would be In the way??
376ci
376ci
Canada
I do have the factory sub yep.
It's in the way until you relocate the printed circuit board that's mounted to the bottom of the cupholders.
08grey
Wow. Sounds like you were really determined. Many of us on here would have stomped it out by then.
376ci
376ci
Canada
Yeah, I was always really annoyed mine didn't come with them. Now it has em haha.
M3kanic
Do you have (or make) an install how to?
Sent from my SM-G900V using Tapatalk
ABNLT
LaCrosse, Wisconsin
That upgrade is sick, however, I don't know if I would have the patience to complete it. You did a great job on it. My question is: do the cup holders get cold/hot enough to make a difference? If so, this might be something I would tackle.
376ci
376ci
Canada
They 100% get hot and cold to the point that it made it worth it.
376ci
376ci
Canada
Depends on what you get your holders for, 350-550.
Then I'd say 15-20 hours of cutting, sanding, epoxying, fitting, wiring.
It's not easy, I was going to make a DIY, but realized no one will want to do it.
You literally need to make custom mounts for the door to mount to, and the holes you see in the top of the console aren't far enough apart so you need to cut the top trim out of the escalade one and graft it into the Denali one.
It's a mission I'm fairly sure no one has attempted before and most likely never will again. But I'd love to see someone else give it a shot, clearly it can be done..
PS, everything's forsale for the right price haha.
376ci
376ci
Canada
There's an interior light circuit, a dimmer circuit, ground, constant power and
Ignition power.
I have fuseable links in both power circuits.
M3kanic
Do you think you could change out the whole center console? And wire up power that way.
Buford bubba
