Heat or a/c.. wrong temp from what's displayed?
stormin
Toronto
Hi everybody
What I have been dealing with... although I've been getting by.... is that when I use to set my heat/a/c to 71 degrees.. and just push "auto" it would put out heat or a/c.. whatever was required.. and keep the cabin temp at that temperature.
I have found now... for example.. as now in the winter.. and I need heat... if I set the thermostat at 71...I get minmal amount of heat blowing out... I have to move the thermostat up to about 82 or 84 for it to bring the temp in around 71.
Same in the summer.... I would have to drop the temp on the thermostat to about 55 or 60 degrees... for the system to start blowing cool enough air to keep the cabin at 71 degrees.
Any idea what the issue might be?
thank you all
as always.. I appreciate your help.
take care
NB
JPeter
