Headlamps
sam123
Tampa
Is this the up/down adjustment screw for the headlights?
Thanks
lynxnova
New Jersey
I'm trying to find out the same thing... I just swaped out my oem 4300k hid bulb on my LTZ to a 6000k and now my view is less then before.. I took some pics to see if the beams were aligned but I can't really tell since I'm not an expert... can anyone tell me if my beam needs to be adjusted alil bit down ?
Sent from my SM-G920V using Tapatalk
lynxnova
New Jersey
@fiatdale... thanks for the info... this sucks!.... all the lights match to the DRL. Including the fogs, they looks great! But then you lose alil visibility... and I just tinted my windshield with 35% which makes my visibility worst.... definitely considering removing the tint on windshied.... smh....
greenhornet
Ontario,Canada
Yes that is the screw. The horizontal cut off line at 25 ft. should be at the same height as the center of the headlight as in the projector lens. It can be on the line or slightly lower on low beam. The adjustment i think is in the owners manual.Or get the shop to adj. it to spec.
lynxnova
New Jersey
Thank u greenhornet... I guess that's what we get to make things look good... suffer alil quality for looks....
lynxnova
New Jersey
How do you adjust the light from right to left?
JPeter
