Headlamps
supadave
How Do I replace the bulb on my 2009 yukon? Can't seem to be able to remove headlamp housing. Removed the two bolts on top but it is still snugged. are there any more bolts needing to be removed or do i just pull on it?
Thanks, david
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
I have never figured out how to remove the housings. But to replace the bulbs, I put HIDs in mine and found the passengerside MUCH easier than the driver side. On the passengert side all you have to to is remove the air intake (simple flat head screw driver is all thats needed), then just remove the plastic pop stop holders and then you can move the black mesh blocking the back of the headlamp and just reach in and twist. Very simple. Reverse to put back together.
Driver side is harder, simply becuase I have huge hands. I was never able to get full access back there. I removed the second battery tray, and the washer fluid tank and got 85% access back there, enough to change the bulbs out.
S
supadave
Thanks rollin thunder pulled out the air filter and poped it in.
ScottS-Michigan
