Head lamp housing removal
rogersinsel
How are they removed so that you can gain access to replace bulbs?
stevek
Dallas, TX
Here's from a quick google search
Driver side: There are about six screws that hold the "spare battery plate" (the battery is on the other side this just looks like an add on plate for a 2nd battery). The washer bottle is also connected to this plate by a screw and I think there is a second screw that holds the bottle to the fender wall, remove that. The washer bottle should drop down a few inches at this point. The neck of the bottle can be pushed out of the way. There is a rubber wrap with some snaps directly behind the headlight. Gently remove the top snap and it will give you access to the headlight. The bulb twists out replace it and reverse the re-assembly.
Passenger side: You basically have to remove the airbox, which in reality is pretty easy. There is a clamp at the airbox for the air tube, losen the clamp and pull the box up and out. this side aslo has the rubber wrap behind the headlight with the snaps. Losen the top snap, access the bulb and re-assembly.
Eickybobby5050
