GMC v. Chevrolet - Does Brand Matter?
WalleyeMikeIII
Sunny and Snowy Minnesota
The glass is the same type in both.
Those options are available with Tahoe depending on how its comfigured. If it's something they want and it's not available in the way they've specified a Tahoe but it is with Yukon or vice versa it's all the more reason to choose one over the other.
We can respectfully disagree on the glass. GMC’s web site specifically calls out Laminated Front Door window glass in the full specs list when comparing trims. Chevrolet does not. I’ve looked at enough Tahoes and actually inspected the window glass edge, it’s one piece. The GMC edge is clearly three layers. The window marking says “Laminated” on the GMC. It says “Tempered” on the Chevy.
Tahoe shows P/N 84753153 for front driver glass
Yukon Shows P/N 84753151 for front driver glass
The fitment notes on the 51 P/N lists Cadillacs and GMC’s. The fitment notes on the 53 P/N lists only Chevy’s.
This is an upgraded (minor) difference in the two that is not well documented.
See fitment notes in links below:
Protect1989
The Z71 and AT4 share a bunch of similar features. Some are standard on one vs. the other, or theyre in a pricey package, etc.
Heated Seats - Standard in AT4+Z71
Cooled Seats - Not Available in Z71, Standard AT4
HUD - Option in AT4+Z71
Air Suspension - Option in AT4+Z71
Sunroof - Option in AT4+Z71
Digital Rear View Mirror - Option in AT4+Z71
Power deploying side steps - Option in AT4, Not Available Z71
There are some weird differences, like not being able to get supercruise in the Z71,not being able to get the Diesel with Tech Package in the Z71 (but available in the AT4), not being able to get power side steps in the Z71, etc.
Basically it comes down to which vehicle gives you all the options/powertrains youre looking for within budget. In OP's case, it sounds like they both do.
So then the question becomes about interior/exterior appearance and if youre a Chevy person or a GMC person
GMCChevy
Looks like they've changed it then and you're right not well documented.
The brochures used to be the best way of seeing what's what but they've started to get too basic with them too.
WalleyeMikeIII
When I got my Denali, I did a pretty thorough scrub to see the differences in it and a High Country...similarly equipped, there was about a $2700 difference. The glass was one of the things I found, there were others...probably the biggest at the time was the inclusion of what is now OnStar One for 3 years on the GMC vs 3 months on the Chevy. Buying the remaining 33 months was $1500 of the $2700 difference. The glass was another, the choice of a lighter interior was another, the availability of eLSD vs the G86 was another. Real wood trim inside, leather in first 2 rows, a few more. I found value in these thnigs and thus felt ok with the slightly higher price. Not everyone does, and that is ok. Point of sharing is that there are differences to be aware of, and some are more than just for looks.
FlynnZero
I am having a bit of an identity crisis as it comes to choosing my next vehicle
Looking at Yukon AT4 or Tahoe Z71. They are pretty similarly equipped and priced.
The kid in me has always wanted a Tahoe and think they look particularly great. Plus, I do some volunteer FD work and a Tahoe would fit in on the fire ground.
However my wife is pushing for the Yukon. She thinks its a bit more of an upscale brand plus our GMC dealer is far superior to any of the chevy dealers around.
I know I would be happy with either one, but I just cant land on one vs. the other.
Go with the GMC. You won't regret it. The Chevy feels like a cheap POS.
GMCChevy
Other then any uniqueness from the oddball trim options Chevy has the same leather as Yukon in the same rows. I didn't know that about onstar. Was that the wifi part? Thats what I saw for 3 months. The rest was several years.
I don't know when they changed but the laminated glass and real wood trim used to be a Denali thing. I did see that as you pointed out it looks like they've switched to laminated for the rest of them. Sometimes Yukon does have better look of plastic wood.
Yes there are differences to be aware of but there are also similarities to be aware of too. Some GMC owners think there's a huge premium over Chevy but that's only because you can get more base Chevy options and higher Yukon trim packages. We weren't looking at the same packages the original poster was but we were trying to decide between the two also and at the end between appearance and the options we wanted we got a Tahoe Premier. Up until then we always had Yukons.
The nice thing about Yukon is a lot of these little things come standard with them whereas you need to pay attention to the options you're looking at with the Tahoe to make sure you get what you want.
blondie70
Back when obamma was president, and he had older vehicles destroyed....(and the GM govt. loan) he tried to get GM to dump the GMC...but they held fast and kept it.
DuraYuk
Gmc is way less common. Its more exclusive. And fleets mostly dont use GMC whereas fire and police use tahoes.
Also the trims. If you like luxury the GMC has way more standard features and some trims like z71 cant be had with ventilate seats but the at4 does come with it.
So there are plenty of reasons. If you dont see them no sense in paying the premium.
Protect1989
Except Yukon has the vertical pad that blocks the feel of spaciousness and view. To me that’s a deal killer…
This is my biggest hurdle with the Yukon. I prefer GMC, but the screen makes the interior feel more cramped.
Im sure once you have it and get used to it its no big deal, hell it might even turn into a perk. The tahoe has more of a spacious feeling interior simply because of the screen orientation
JTGZ71
All good points made here. I have a 2023 Tahoe Z71, and while I really like it, in hindsight, if I had looked more at the Yukon AT4 and really studied the differences, I might have gone that route. Many of these things may have changed with the 2025 models, but here are the main things that I either wasn't aware of or didn't fully appreciate, at least when I bought my 2023 Z71:
1) No adaptive cruise control available on the Z71. I knew I wasn't getting Supercruise, but I just assumed it would have ACC. Pretty annoying to not have this feature on a $75k+ SUV. Shame on me for not researching ahead of time. I saw a button on the steering wheel to set the distance between my vehicle and the vehicle in front of me, and I assumed it had ACC (but I guess it's just for emergency braking). I believe this is now available on 2025 Z71's.
2) No ventilated seats available on the Z71. Not a dealbreaker, but wish I had them. Again, shame on me for not researching. Maybe this is also now available on 2025 Z71's.
3) Taillights on Z71 not full LED (i.e., I think the turn signals and reverse lights are non-LED). Not a big deal, just doesn't look as good. Again, I believe this has been updated on 2025 Z71's.
4) Infotainment screen in my 2023 Z71 just looks kind of old school and tacked on. This has been fully addressed in the 2025 models and some people like the Chevy style better and some people like the GMC style better, so it's personal preference.
For me, exterior looks are kind of a push between the Z71 and AT4. I like them both. Interior on AT4 is probably a half a step up compared to Z71, but not a huge jump in my opinion (not all the way up to Denali level). I could take or leave HUD - those never show up very well for me in any vehicle when I wear polarized sunglasses, so it's kind of a nice to have but certainly not a necessity (for me).
Long story short, I agree with anyone who says you can't go wrong with either. But as someone who really enjoys my Z71 but still has some very slight buyer's remorse for not getting an AT4, I would recommend you study and understand the differences between the two very well before buying.
Johnny Fr
Since your wife has a say - she may be right about the superior GMC dealer.
having owned a Buick and having been to every GMC dealer within 50 miles of where we live, I’m really hoping Chevy will be better. Maybe a pipe dream but Chevy sells more vehicles. Buick service was sub par and out of warranty went to an indie garage (got Bilstein B6 front/rear installed for $440 labor or $850 out the door). As far as the cars I agree GMC is more upscale such as stereo and massage seats etc. but the screen being vertical doesn’t look good to me, yes, something that simple. Also Bob Seger’s Like a Rock is for Chevy
Wilmington, NC
"YUKON DO IT!" Seriously - I've had two XL Denali's and one 2011 Chevrolet Suburban LTZ - For me it's Yukon all the way but I would not buy anything newer than 2019 or 2020. Good luck.
h0m3w3CkeR
Virginia
i have always been under the impression that, GMC is chevy’s upscale TRUCK brand. Seems like GMC has a bit more prestigious add to the fact it’s usually grouped with Buick (which, once upon a time, was considered a luxury car just shy of a Cadillac) as opposed to Chevrolet which is considered entry level.
That being said, I’ve never agreed with GMC styling. I don’t think there’s a single GMC truck ever made that I’ve liked more than it’s Chevrolet counterpart.
Years ago i almost pulled the trigger on a GMTY900 Yukon. It was a beautiful red color but i just could not get over the ugly ass headlights and front fascia.
Haha..I agree, the front end on my 23 Tahoe RST sold me.
SavageDad
It still infuriates me that the Z71 wasn't available with cooled seats, as much time as I spend on the road and in the dirt and as much money as I spent on the damn truck the seats should've been cooled, massaging, and provided stock tips!
SavageDad
Same boat really, I wish I had taken my time to do more research before we bought our Z71 Suburban because a few of those things like the cooled seats would have been deal breakers for me had I not just assumed that for nearly six figures cooled seats were a given.
steiny93
I do agree that the GMC brand and dealership/service experience is a notch above Chevrolet (which is crazy considering the cost of Tahoes now).
This part is 100% dealer dependent and nothing to-do with the brands
I've spent time working in both Chevy and GMC dealers; they are the same, the difference is how they are operated.
homesick
The Best Me I Can Be
Navy Air Force
Thanks for saying it again.
LOL, maybe there's a reason that 'obvious' and 'oblivious' look so similar.
joe
Tupapi
