getting tickets
jaysZ71Tahoe
one headlight out, dim bulb right side,left side works and so do all other lights. replaced bulb no luck, I have searched forum and on line for info but no luck hopefully some one can share knowledge on this thanks all. oh and I will look at fuses and or relay and check voltage in the am.:Jedi:
blakeaasgaard
Same issue with me. Left side functions as designed. Right high & low beams both burn dim on low switch, and both go out on high switch. All fuses and relays check out. Ground wire refreshed, and supplementary ground wires spliced into good connections at the lamp sockets.
S33k3r
Dallas, Texas
Check the positive cable between the alternator and the battery. I have heard of that cable disintegrating inside the protective case, not letting enough power through the system. Also check the alternator. If it is starting to go,you can see the same thing.
TallHoe 96 OBS
