gears clunking
ridehuff
bismarck ND
so recently something in my rear end is clunking. has that sound when you rub ur tires, if u know what i mean. its not jerking or anything but it clunks almost constaomently. someone said that it doesn't seem like the spider gears, he thinks a loose pinion or something. anyone have any clues?
bowtiefreak
No Quarter
Near Philly
Could be the G80, the limited slip getting ready to go. Open up the cover and see if anythign jumps out as being wrong
Abstrastic
Ft. Worth
yeah sounds like the limited slip or even like you might be low on fluid, bearings could be shot as well. Pull the cover and see if anything looks out of place or if you have any side to side movement in the carrier. Just grab the carrier with you hands and try to move it, it shouldn't move at all side to side/
retorq
Kingman AZ
If your pinion is moving it WILL grenade itself pretty soon. Start buying parts. LOL
96ProCompTahoe
IN
should also have metal shavings in the fluid if somethings about to let go in it.
blueflamed03
Oklahoma
pull rear diff cover, see if the G80 like mentioned exploded.
If so, time for a TrueTrac.
bowtiefreak
No Quarter
Near Philly
pay close attention to the fluid coming out. It could tell you a lot. Looking for peices and so on.
R
ridehuff
bismarck ND
pulled the cover and never seen anything like this. limited slip, gone. bearings, absolutely gone. carrier, shot. anyone know what i should do now?haha
blueflamed03
Oklahoma
Ron's Differential time.
R&P and TrueTrac
I think for Truetrac, gears, master installation kit is like $650
moto
