Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Likely the brake pedal switch may have partially failed and the interlock is not releasing. Can you turn the key just to unlock the wheel and move the shifter just fine but with full power on and brake depressed it stays locked? Do you here a clicking sound on the right side of steering column when you depress the brakes when key is full on? Check on fuse #16 TURN B/U so see if it has fizzled on you.
I jiggled the brake light switch, and it worked just fine after that. I did not have brake lights before now all of them work except the third brake light. can this be the brake switch also?
---------- Post added at 05:47 PM ---------- Previous post was at 05:41 PM ----------
it uses the same wire on switch to feed the center high and go thru the turn signal switch to feed the lower tails. they split in different directions thru a splice. the center high is of the led type. Un-mount it and get a test probe on it to check for problems.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
