Gear ratio suggestion
pmackiniv
I have a 1996 GMC Yukon SLT sitting on 35/12.5/15's and I was wondering if replacing the stock gears with a 4.56 gear ratio would make the gas mileage worse.
Sent from my iPad using Tapatalk - now Free
KPOD
Michigan
Yes, but you'll have better pickup and go :D I know people have said with bigger tires, if you don't re-gear your torque converter next locks which can cause havoc on the drivetrain.
pmackiniv
pmackiniv
Whatever the stock gears are. I'm pretty sure they're 4:10.
pmackiniv
pmackiniv
I stand corrected then.
---------- Post added at 10:47 AM ---------- Previous post was at 10:35 AM ----------
stock 4.10's my ass. you either get 3.42 or 3.73 from the factory.
What would you say about rehearing the torque converter fo stock gears like that?
---------- Post added at 11:59 AM ---------- Previous post was at 10:47 AM ----------
What would you suggest for researching particular types of GMC models that would have bigger rear end doffs? I'm looking to find one out a junk yard.
bowtiefreak
No Quarter
Near Philly
Ideal set up for our trucks with that size tire are 4.56 or 4.88. And Sunlit is right on the gears you most likely have. 3.42 or 3.73 is stock set up.
autolover3
Bismarck/Wahpeton, ND
You don't regear a torque converter. You can buy different TC's for different stall speeds to help bottom end get up and go but with a low ratio will cause stress on drivetrain with big tires.
Also pmackin... I posted some helpful info on your other thread regarding axle ratios and RPO codes
2doorbamahoe
Fairhope, al
I wouldnt worry about gas mileage, I think gas mileage should b forgotten with any older 4x4 v8. Especially with 35s. Just do what's best for truck!
bowtiefreak
No Quarter
Near Philly
I get great mileage. 12 in both doesn't matter highway or city. I do drive them hard. If I wanted great mileage I'd get a little car
Tadsher
