gauge cluster
the big blue bus
richmond, va
i got from the junk yard a cluster that has the tach that goes to 6000rpm and changed the odometer to read mmy milage and cleared the needles but now the gas and oil gauge dont seem to do anything but when i plug the orig cluster back in they work. how can i fix this? any ideas thanks
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I have diagrams for the '95 but they do not specify how far the tach goes but I also did find out that there were two different clusters used that model year so the only thing I can suggest it set them side by side and compare the circuit traces to find out if there are two signal circuits broken or the layout has changed and hot wire them to replicate the original by following its layout.
the big blue bus
the big blue bus
richmond, va
i hope i can fix it. i spend all that time changin the odometer to the milage i have and clearing the needls for when i get blue leds. they workd before i took the needls off im pretty sure so i musta messd something up
AtomicHoe094
Atomichoe094
cleveland, OH
only thing i can think of is when you take off the needles, maybe you didnt put them back on where they were exactly in the first place.. soo say the fuel was one a 1/4 when you got it, you took off the needle and placed it to full. maybe it messed it up??? i have no idea. weird.
AtomicHoe094
Atomichoe094
cleveland, OH
idk i dont screw around with needles. The fuel gauges on these trucks have so many problems anyways, thats why i just swapped out for escalade gauges and called it a day. No screwing with the needles and getting them off center or what. They are temperamental tho.
the big blue bus
the big blue bus
richmond, va
well they all work now tried it again.. but now my passenger mirror wont go down. it will move everyway but down ugh
SunlitComet
OBS Jedi-Do Good
The same motor is used for up/down functions so if it is just the passenger side that won't go down but will go up that is definitly your switch. All it does is switch between and reverse the dc current to the motors so at least you know your wires are intact.
SunlitComet
OBS Jedi-Do Good
yeah. If the passenger goes up but not down then all the wiring and motor are good the only difference between the two directions is the electric flow inside the switch is reversed for the motor. Ther are about 30 electrical contacts in that switch that could fail.
briannorris
