Gas smell
Skizzot
Usa
My research has produced every possibility imaginable.
I parked my truck at airport parking for two weeks in order to fill in on a band's national tour. Upon my return the truck started right up and ran perfectly all the way home. Once I turned it off and stepped out an hour later, I smelled gas near the rear of the vehicle and assumed it was just from my neighbors mowing their yard at the time.
I got back in it a few hours later and it continued to crank without ignition. I cranked it again and it started right up. It's obviously losing fuel pressure and takes longer for the pump to build up enough for start up. Upon exiting once again I smelled gas near the rear driver side. I've heard about the vent sticking open and requiring replacement, but the smell is strongest near the fuel tank where the parking brake cable splits into 2 cables. Any thoughts?
Skizzot
Skizzot
Usa
Found the problem. The fuel pump is so badly corroded that it is leaking a LOT of fuel.
Skizzot
Skizzot
Usa
As an Amazon Associate we earn from qualifying purchases.
sainmegroll
