Fuel injector spider replacement: MESSED UP
insadj05
Iowa
I pulled a major screw up. Put one injector spider in the wrong hole. Has any one done this? How do U get the new injectors out? The Delphi has a different design then the old one with the tabs to grab!! :emotions122:
I
insadj05
Iowa
Yup. That worked. Thought I really messed this thing up. All is well. Thanks
RedCrush
the delphi one gets a little better fuel economy and is great! its a big time difference, acceleration doesn't feel as sluggish, smoother idle...
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Why did replace it to delphi?
Is there any performance change?
Delphi or ac delco will do but ACDelco price is higher. it is the same Delphi unit either way. Delphi is the oem supplier for the factory on this component. the reason for changing them is because the original design from gm had issues after about 100,000 miles. so the redesigned it for improved operation and reliability.
agmanw8n
