front bumper pad
alxs210
Reno, NV
Is there a way to remove this without removing the whole bumper?
NorthOC Ca
yea remove your grille and lights and pull it off. be careful though, its held in by little tabs that go into the bumper their kind of tough but will still break. its easier to start from the outside and work your way in. why are you removing it?
alxs210
alxs210
Reno, NV
Thanks! I want to repaint it and get rid of the texture.
NorthOC Ca
its a shame you dont live closer to me, i just did the full HD conversion and i have that piece taking up space in my garage and i want it outa here. but good luck man, just be forcefully gentle with it and shell come right off!
alxs210
alxs210
Reno, NV
dude, ill buy it! pm a price, we can work something out! 89502
KAKALAK
man I seen an avalanche before and the person didnt sand off the texture before painting and it looked terrible.
Tahoebigdog03
should i sand my door handles or just buy some new ones...........mine are black
KAKALAK
you can sand with 320 then 400 to smooth them out. Degrease then use Bulldog Adhesion promoter (2 coats) on them, let dry then base then clear.
it would most likely yield a better finish if you remove the handles and the bases to work on them. But its not required.
---------- Post added at 08:01 PM ---------- Previous post was at 08:00 PM ----------
you could also spray them with a high build primer then paint but not that rattle can crap. Doing that may keep you from sanding them down. Test one out
Tahoebigdog03
Cool thanks... so I can do this without taking the handles off or is it best to removed them.I also would like to my mirrors and back panel by the tail gate.
Thanks for the feed back.
KAKALAK
yeah you can do with them on but it will be tiresome on sanding and you run the risk of scratching your door. the back piece and the front valance piece I would just leave on the car paint.
I just picked up a 2001 and Im going to start a build up on it in here. I usually do pretty good step by step builds. Im a lowrider fan but bought this denali for a hauler and a family ride.
MADDOG54
