[FOUND] Wanted: PPV steelies with caps
Prospect62
Central NY
I think I want to ditch my 20's and go with PPV/SSV black steelies and center caps. I'm located in NY state but I will pay shipping costs if necessary. I'll consider just the wheels or wheel/tires together.
Also would be willing to trade my 20's with excellent Michelins on them for a set of police steelies with tires mounted if anyone is nearby.
Thanks!
Marky Dissod
Guessing you mean GMT921 17" PPV/SSV steel wheels, instead of the GMTK2xx 18" PPV/SSV wheels, or the GMTT1xx 20" PPV wheels?
Which ones:
Or did I miss it?
Prospect62
Prospect62
Central NY
Sorry.
I'd consider GMT900 or K2 versions.
None of what you posted is what I'm looking for.
Marky Dissod
What that site does is offer wheels CHEAP - 17" 6 bolt-5.5" circle steel wheels that work on everything from GMT400s to GMTT1xx are $50 apiece.
What the site does NOT do is 'know' anything other than the immediately obvious.
The less you know about which 17" steel wheels you want, the longer it'll take to find what you want - and they don't use GM part numbers, so you SEARCH ...
k_arnold72
Any interest in gm transport wheels? Located in MD.
Thanks!
Make your own. I grabbed the everyday steel wheels, painted them black, drilled and tapped holes for the center caps bolts. Instead of using the ppv sized tire I went with 265 70 17.
Prospect62
Prospect62
Central NY
Will do!
I ended up getting a set for a K2 with the black caps, and then I bought a set of the chrome caps because I can't decide which is going to look better.
Charlie21ny
