Fng
turbhoe
maryland
iwaslowr invited me over after seeing my vids on streetfire.net. so, i thought i'd say whats up to everybody. tahoe mods are in my sig. its a fun daily driven ride.
blueflamed03
Oklahoma
post some pics and tell us about your combo...sounds like a fun ride.
welcome to teh site :cheers:
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
Welcome! :cheers: Thanks for joining, I'd like to see some more pics and vids of your Turbo Tahoe!
T
turbhoe
maryland
i was at work when i set up the login so i couldn't do the sig pic and what not. 56k stand by.
---------- Post added at 03:40 PM ---------- Previous post was at 03:18 PM ----------
it says my sig pic file is too large. which is weird i use the same one on all the forums. anyway here are some pics.
bone stock
intercooler hole with wifes pink arkansas razorback.
gauges
first homemade air box with ruber seal to seal off heat.
new IAT sensor in manifold
new lower valance, a mix of HD parts and 05 tahoe parts.
new wheels
blued bumper from meth flames. :)
new stronger airbox with small scoop
twist in out put shaft splens on trans
chucnks from same trans
broken axle
12.89 time slip
just a sexy pic
broken detroit locker
axle cross bones. both from left side
broken inner bearing race off locker
T
turbhoe
maryland
vids of truck
the turbo hot pipes are from trick as is the intercooler. the turbo is a tc78 turbo. 3" downpipe with a 4" duramax exhaust with magnaflow muffler. stock the tahoe is AWD. that case is not ideal for racing with this much power. so i went with a SSS t-case. but then my front end started to whine. so i pulled it out and installed a modified autotrac case. i took all the 4wd parts from the case so its only 2wd. that's whats in there now until i get the front end back together. torque converter is a yank sc3200 and tune is done by me with hptuners. its running seimen 60's for injectors and dual fuel pumps. and a zo6 cam with ls6 heads that have been port and polished. running 10psi on the street with a high boost switch that gives me about 12.5psi.
i have a new cam on the way. can't wait for it to come in.
here are my guages. they are made by defi
stock with personal tune and magnaflow muffler.
http://videos.streetfire.net/video/first-tahoe-race_152421.htm
here is one when i first got the turbo on and was learning how to fight the torque steer from the AWD. wife kinda freaked for a second. the tahoe jerked hard left and about smacked a car.
http://videos.streetfire.net/video/turbo-tahoe_153117.htm
this is one of my favorites. the wife was driving and her friend was with her. if you look close her friend is waving at us but it looks like she is waving by to the mustang. also note the crowd at the end of the vid.
http://videos.streetfire.net/video/tahoe-mustang-race_158247.htm
this is a vid for my stock and 4" exhaust
http://videos.streetfire.net/video/old-new-exhuast_169877.htm
13.2 run
http://videos.streetfire.net/video/turbo-tahoe-132_705866.htm
12.89 run vid is fuzzy but you can here the guy call the times.
these runs were made after going 2wd. doing so my rear end didn't like it. here is what 7psi launch will do.
http://videos.streetfire.net/video/turbo-tahoe-breaks-axle_719346.htm
---------- Post added at 04:06 PM ---------- Previous post was at 04:04 PM ----------
dang, you always can find the next weak links when putting that kind of power down :D
tell me about it. that's why i want the awd back. help transfer the power to all 4 vise just the two.
T
turbhoe
maryland
haven't got to a dyno yet. i really want to before i go back AWD. i found a local dyno i may try out. incase you guys didn't know, if you want a stronger rear axle with out alot of trouble. you can go to a new model escalade axle. the 6.2l ones have 14bolt 9.5" rears that have the same suspension as us and it will bolt right in.
thats one of my future mods. but i think for now with the awd going back in i should be fine. i hope.........
thanks for the complements guys.
ZaZaZazzels
