Fiberglass box build
ckl5899
ckl5899
San Antonio
I have everything but the battery for both the big 3 and second battery. Just researching what battery to get to complement my stock battery
Modded
That Guy
Get a Kinetik. They are sick. XS Power and Odyssey are also good.
Modded
That Guy
Yeah it will but it would be better if you get two. One for the starting battery and a second one in the other battery tray.
I put Duralast platinum batteries in mine. They are the same batteries as the Deka Intimidator AGM batteries.
phattyford
Dirty South
yeah, i wanna know this too...I wanna put two Kinetik batteries in my hoe but unsure of which ones to get.
Denali0229
FL
The largest kinetic that fits the stock location is the HC2000. I think the 2400 is a little too big without modifying anything.
Sent from my PC36100 using Tapatalk 2
Modded
That Guy
What size battries?
BCI Group 34 or 34R batteries. 78 will also work.
If you are looking for a pure aftermarket electronic battery (like Kinetik, XS Power, and Stinger) then look for ones that mention the size specs are similar to those 3 sizes.
---------- Post added at 03:31 PM ---------- Previous post was at 03:27 PM ----------
If the HC2000 fits, it will be a very tight one. The HC1800 would be a perfect fit because it is a 34/78 sized battery.
jdpber
GOLD MEMBER
The America
^^^ preach it man.. Battery over a Cap.. cleaner and purer power.. do not eat up too much of your air space with the amp area in that box.. that area you are working with is already at a premium.. and 3 large drivers will eat air space.. do your measurements and account for driver loss first before you do your final glass.. last thing you want is to drop the cash on the glass and resin and starve the speakers of much needed air..
ckl5899
ckl5899
San Antonio
Suprisingly it has quite a bit of space. Almost 14" at the bottom and abot 9" at the top
dgjtools
