Exhaust smell in cabin Escalade 2021
maddocmatt
Hey everyone. I have Escalade 2021 Esv, 6.2 liter, performance exhaust and air filter. This truck had the lifter issue on the 1357 bank replaced at 14k miles.
I had taken the truck in for regular service at 24k miles. Standard stuff and they also did the transmission and diff service.
Ever since that service there is an intermittent smell of exhaust that comes into the cabin mainly on the right side. It’s mostly noticeable at idle. And if you turn circulate air on it goes away.
I can’t get an appointment at the dealership for like a month but it is really annoying.
Any thoughts would be appreciated on what it could be. I’m worried it’s intermittent and the dealership will dismiss it.
Thanks!
I cannot personally help you with your question; however, other members on this Forum that are much more knowledgeable than me will chime in.
TexasLC
If it were me I would take an afternoon and drive it over there. CALMLY wait until a service manager can see you. I’d check in with an advisor every 20 minutes. Be patient and calm and I bet you’ll get help. If it takes 2-3 hours then so be it. Exhaust coming into the cabin isn’t something to mess around with so I would be persistent and patient and firm in asking for a quick once over. My relatives F250 did this and after he drove it over they took his car in ASAP to get it tended to. It was a safety issue.
B-train
Is it possible you have a cabin vent that is stuck open? I had that same thing happen on my 2008. When I only had the sunroof open I would get dust inside the cabin and the faint whiff of exhaust. I found out that the air flaps to release cabin pressure were gone. They are located above the rear taillights, under the trim piece.
I'd try driving with the air blower OFF, and try to create a vacuum in the cab with the sunroof opened. See if that changes anything.
M
maddocmatt
Thanks everyone. This truck has been in the shop more than on the road. I’m so close to dumping it.
M
maddocmatt
Thought I would throw an update out there. Still can't get in to see anybody at the dealership. BUT....I have at least a theory and I wanted to see if somebody could comment. When they did the lifter repair I am pretty sure they had to remove the exhaust manifold. Given that the smell seems to be coming from the right passenger side more than the left (wife can smell it more than I) and the 1357 bank I believe is on the left side of the truck (battery side), could it be that the manifold might need to be tightened or something? AND if it were could I inspect it and do that?
WalleyeMikeIII
Sunny and Snowy Minnesota
I would not attempt any repairs yourself that you think were caused/introduced during the OTHER warranty repair...or a general delaer service.
The exhaust manifold may have had to be removed to do the initial repair. There could be an issue w/ the gasket, the torque on the exhaust manifold bolts, or other issues.
You may be able to inspect and see if there is a leak (looking for carbon on or around the exhaust manifold), or by opening the hood and listening...you might be able to hear if there is a leak or not...
Also, another possibility is that there was oil or coolant spilled onto the engine or exhaust during the repair, and these need to burn off before they go away.
It could also be an exhaust leak below the engine, in the exhaust pipes/clamps (not sure if they may have had to remove the exhaust to drop the transmission pan to perform the transmission service)...you might be able to inspect this under the vehicle yourself.
Incidentally, why did you need transmission service at 24k miles, the severe service schedule calls for transmission and transfer case service at 45k miles, and normal is 90k miles, but i would never go that far.
M
maddocmatt
I have to apologize. It was transmission it was transfer case. I thought it was weird that it started after service. I don’t hear any ticking, no loss of power, no gas mileage issues. Just the occasional smell of something which I thought was exhaust. I have to say I’m super frustrated with Cadillac service in general. Can’t get in. Nobody can help. No parts. No loaners. Freaking abysmal.
WalleyeMikeIII
You can take your vehicle to any GM dealership, doesn't have to be Cadillac...
M
maddocmatt
Wait…I thought they told me that you had to take it to Cadillac only because regular gm service is not certified to work on them. Is that BS? I have a faulty l left rear taillight that goes in and out. I have to tap it to turn it on. I would love to get that fixed too
WalleyeMikeIII
Well I was wrong, according to this page, it implies you need to go to a Cadillac dealer, unless it’s an emergency; which possibly you could be in since exhaust in the cabin is sort of severe/safety related issue…
Making me glad I bought a Denali!
M
maddocmatt
LOL you should look up my post where my Yukon Denali 2021 stranded me 4 times and I had to lemon the truck. This is just another incident in a long line of incidents :)
I would take that statement with a grain of salt, it clearly says "or" when a Cadillac dealer is not readily available.
you can have any gm warranty part repaired or replaced at any gm dealer.
WalleyeMikeIII
Was Kind of thinking the same thing…thought GM went to a policy of getting Warranty work on any GM vehicle at any GM dealer when they consolidated the brands…but the Cadillac info above sort of says no…if the dealer was 30days out, I’d give it a shot.
M
maddocmatt
New update. Can’t get an appointment at any dealership within 30 miles. I have called and left messages. I’m at a loss on what to do
Stbentoak
It’s kinda like taking a Bronco to a Lincoln dealer… if they would even talk to you, they would certainly put you at the very bottom of the line. That is if they would even talk to you…You’d have better luck taking a Cadillac to a Chevy or GMC dealer then vice versa in my opinion….and the odds would still be low….
not sure why they use the word "must" in the Cadillac link above
because the bottom line is your vehicle warranty is covered by any GM dealership (nationwide).
although smelling something is probably not a legal issue if a co2 monitor triggers inside the cabin that likely would be a safety problem
it's came up before, not sure if the op ever reported back with a final resolution but it certainly got the dealers attention.
M
maddocmatt
I have not been able to secure an appointment yet.
I was referring to a c02 trigger from another owner that also smelled exhaust, when they brought it to the attention of the delaer they were on it fast.
I also find it hard to believe a delaer can't get you in for appointment is this like a single bay dealer or something, my dealer has at least 15 bays and they can knock out stuff left and right
Conedaddy
