Engine ticking, GM ticking me off!
lamerem
Ugh, the frustration consumes me.
2011 Tahoe LT 4WD, 77,000 miles. Engine started making this ticking noise from the passenger side head area about 4 weeks ago. It never goes away cold or hot and the ticking increases with RPM. Made an appointment and took it in. The technician verified the ticking noise but couldn't pin point the source. The invoice states that the exhaust was checked with NO leaks detected. States that the tech contacted GM TAC and they advised to remove valve covers and inspect the rockers and lifters. Dealer called me and said if they didn't find anything covered by the 5yr/100,000 mile PT warranty then I would be responsible for all costs (around $700). I expressed my dislike with this. If GM is saying to remove the covers then they recognize there is probably an issue internally or know of a common issue with rockers and lifters. I contacted GM directly and have gone round and round about this finally they said they would cover it. When I called the dealer they said they knew nothing about this. I then called GM back and got the run around that the case had been handed off to a Senior Advisor and she is now back peddling saying only one hour will be covered of the labor costs. I am completely frustrated. I have a truck with a ticking at 77,000 miles this should not happen. Everything I have seen online talks about lifters going bad, mainly the ones associated with the active fuel system.
Now the Senior Advisor began consulting with her supervisor and I haven't heard anything back yet. My thinking here is this: If GM is advising to remove the valve covers and perform an inspection then that should be covered. It wasn't like they said well if you want to look further that would be the next step. They flat out said that needs to happen. My family only owns GM vehicles and have been longtime customers. I have had GM cars with 200,000 miles on the original powertrain without major repairs. Now I have this $50,000 4 year old Tahoe with 77,000 miles and it has a ticking noise and GM says I should pay for all but an hour of labor. That is crap, it is a 5 year/100,000 mile warranty. If I have a powertrain concern it should be looked at cost free. Go the extra mile GM, these engines should remain problem free longer than this.
iLikeEggs
Potato!
Oregon, USA
I have a 2011 police SSV with 127k on it. Sometimes I hear the ticking, sometimes I don't. I seem to hear it less frequently after I switched to Mobile 1.
The AFM on mine just shakes the vehicle, but not always. Sometimes it's as smooth as silk. I may disable it at some point but I'm trying to squeeze some economy out of this thing.
bvilchez
OP , I will tell you I have experienced the exact same thing within the last 2 weeks. It ended up being the oil pump or the o-ring which connect the pickup tube assembly to the pump but I replaced both and now I'm back to normal.
What led me to this is I had a ticking just like you. I read forums and saw YouTube videos galore. Then I read a comment on a video that mentioned the oil pump and it made sense.
I have one question for you. Do you have any changes in your oil pressure gauge?
lamerem
lamerem
No, my oil pressure gauge is stable. It hasn't changed one bit. Sound is only coming from the right head area. Someone on here said something about the AFM lifter flattening out as well. I don't know what to think. I know GM should man up and rectify the issue.
iLikeEggs
Potato!
Oregon, USA
I think that issue with the oil was addressed by GM. After Feb 2011 the 5.3's c with a redesigned valve cover that prevented the oil issues.
AZSCTACO
Phoenix, AZ
Bad lifters and cam......thats what was replaced on mine years back. No issues since. Same ticking sound you have.
lamerem
lamerem
That's what I was thinking. Just wish I could get them to own up to it and pull it apart. I don't feel I should have to pay diagnoses fees regardless since the engine is ticking.
AZSCTACO
Phoenix, AZ
I'd be very surprised if they haven't seen this issue before. It's a very well known issue and TSB's have been all over the place regarding this. I don't know what they are worried about getting your $$ for diagnosis. They get reimbursed by GM for all this warranty work.
lamerem
lamerem
There stand is that if they don't find anything covered they want my cash for parts and labor. My stand is if your team is advising then you do it on your dime.
AZSCTACO
Phoenix, AZ
Odds are, there gonna find something wrong. And it's going to be a drivetrain issue. I would just bring it in and say find it and fix it b1tches!!! :)
