E-fan problem
04 TAHOE
Pelzer, SC
installed aftermarket e-fan with thermostat that goes in the upper radiator hose. Now have problems with air conditioner condenser staying on and blowing cold air especially at idle. Any ideas if I did something wrong or does ac need the clutch fan for some reason. Had no issues before changing fans.
crmzendrgone
M town Arizona
Not sure I follow you there but I am thinking you mean blowing hot air at idle. If that is the case the COMPRESSOR may not be coming on do to the temp being to high for it to run efficiently
04 TAHOE
Pelzer, SC
The engine temp is still running normal just a hair below 210, and you can hear the comp kicking on and off at idle it just stops blowing cold air when idle. Seems that taking off the clutch fan has changed this for some reason. Is the cl fan and compressor linked together when the air is on? If it is a temp problem with the compressor how do I fix that?
Thanks for any help!
TERRYCCTT
FRIENDSWOOD, TX
Simply put the air from your fans are not enough or not on with the ac. The condensor gets hot and raises the pressure so it turns off the compressor
04 TAHOE
Pelzer, SC
So I adjust the thermostat on the fan to turn on at a cooler temp and this will help the compressor?
Thanks!
TERRYCCTT
FRIENDSWOOD, TX
Best bet would run a relay to the ac relay for the fan to come on at the same time as the ac. The reason is high pressure in the compressor is bad. it will eventually ruin it. you can run the same trigger for the ac to the relay for the fans and it will work the same
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
just use a diode so the fans don't turn on the compressor :)
TallHoe 96 OBS
