E-Brake Chime... Won't turn off
GSDunk
My E-Brake warning light in the center cluster won't turn off even though the E-Brake is fully released.
Now the chime is on constantly unless I brake, stop or put it in park.
After 5 minutes of constant chiming, you want to smash your head against a wall.
How hard is it to get to the chime speaker on a 2003 Yukon SLT? I would remove it instantly if fairly simple.
03YukonNH
Manchester, NH
Check to make sure your brake fluid isn't low. Same thing happened to my 1994 Bonneville when I was in college. Had no idea what was going on
PG01
Up here to the right
Look under dash by the ebrake... make sure the contact is fully off...if not unplug it there..
GSDunk
GSDunk
I'm not quite sure what you mean by "make sure contact is fully off"..... What contact?
PG01
Sumthin like this here...
