bjeremi
You guys will have to forgive me as all of this is a learning process and I am just trying to understand a bit more.
I recently put McGaughy 2" drop springs on the back of my Hyhoe (Thanks 07Burb) and now want to bring the front down an inch. It seems the way to go is to use these (drop/lifting struts):
http://www.belltech-store.com/products/lowering-lift-shock-7254.html
My question is why those and not these(drop springs):
http://www.belltech-store.com/products/pro-coil-spring-set-6980.html
Or maybe replace both?
I only ask because until now the only suspension work I have done is replace worn out shocks and farm boy weld a cracked leaf spring mount on a boat trailer. I recently did put TRD (performance springs) on my wifes prius (yes Prius, holding my head in shame) just to lower it and improve handling a little. The prius kit just replaced all four springs and did not change the front struts.
Anyway just wanted to see anybody had some knowledge to share and explained it my uneducated self. Thanks.
