Door panel removal 04 Escalade
95escahoe
Trying to remove the pass side door panel on my 04 Escalade does anyone have a diagram? I know you pop off the triangle trim, pop off the bezel around the door handle, and there are a few screws? Anything else?
MikeLade
Pop the trim off from behind the door handle and remove the bolt, remove the bolt behind the door pull (armrest), pop the window switch out, pull the triangle trim off and lift up. There are "L" shaped brackets that clip into the door. When you pull up, you release them.
95escahoe
95escahoe
Thanks for the help, these are a lot easier then OBS Tahoe door panels
HeavyHoe03
