Does anyone know how to calibrate the instrument panel needles?
AllenFinOR
Hi Folks,
Does anyone know how (or if) there is a way to recalibrate the needles if you pull them off the instrument cluster? I am doing some modifications to the cluster that requires that I remove the needles...
Thanks for any tips!
Allen
HiHoeSilver
Away!
Chicago
Hi Folks,
Allen
Best is to mark them on the face with tape and a pen. If you're changing the face, you can do your best to copy your marks onto the new one.
Also , when you turn the key on and off the gauges go to zero. You can use this as a calibrating point.
AllenFinOR
AllenFinOR
Thanks so much! As crazy as it sounds, I am adapting and modifying these to go into the dash of a 1956 Chevy Pickup cluster. Hopefully it doesn't turn into a cluster foxtrot!
Allen
Durobans
