Kpwweb
- Joined
- Dec 11, 2015
- Posts
- 771
- Reaction score
- 357
I would not assume the dealership checked the starting system.jfoj, appreciate your insight and my first thought was also battery or low voltage issue, but it was towed to the dealer and I have to assume they checked the charging system and battery as it was showing the same codes while in service and being diagnosed. Once they saw the module on the ECM, they pulled it and all codes gone. Picked it up on Saturday and module is enroute back to Range for testing/replacement. Tahoe running fine since. In all honesty, for what it does, and the inconvenience it "may" have caused is just not worth re-installing, especially on my wife's daily driver. I will definitely update this thread if these codes reappear or similar issues arise.
I also agree with jfoj. The factory batteries are junk. I usually have to replace them within two years. At least on the last two Tahoes, when they start acting flakey, new battery goes in. One even tested “good”, but did not have staying power. It would fall flat in the cold. Good battery will solve a myriad of issues.
