Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Before I go breaking things--
The blank spot under the rear hatch switch...Can I just pop that out or do I have to remove the dash face to get it out?
I'm doing a mod and I need to put an LED light there.
What? When I play with mine I don't have to take the dash trim off. Those three plates are one peice. Just use a small jeweller's flat screwdriver to carefully pop it out. There is enough length of wire so that the blank comes out enough for you to work with the wire connectors to disconnect it. The trick is to go slow, take your time. If you are really carefull and patient enough then you can mix and match plates with other things.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
