Customized DashCommand Dashboard w/ trans temp
treehan77
TYF Fiend
Crestview, FL
Just in case any of you use DashCommand, I customized an existing dashboard to work with our trucks that shows transmission temperature gauge. It has several screens, a button to turn light or dark and displays lots of info.
Dashboard
Comments welcome. I did not create this dashboard, i just changed bits of it to suit my truck.
treehan77
treehan77
TYF Fiend
Crestview, FL
You can use the regular fuel PID, the GM seems to work better for me but there's a general one that works. You can type that one in instead if you edit the dashboard
TheAutumnWind
Very cool. I heard about dashcommand recently, (only ever used torque pro) and have been meaning to mess with it.
Five
North Carolina
Is anyone able to get trans temperature on Torque Pro? My '02 Suburban shows no data...
evldave
For Torque Pro, load the extended GM PIDs from the settings menu, then use Trans Temp 1,it should read fine
edit: Just checked, the actual PID is 'Transmission Fluid Temp (GM Method 1)'
#1taho
5150TAHO
niagara falls ont
Dashboard
What does this look like? Any pics?
treehan77
treehan77
TYF Fiend
Crestview, FL
Durobans
