Cruise Control not working
leonpiper69
Eastern PA
So I found something wrong with my new 07 **...... :(
The cruise control does not work at all. IT lights up when you press the on/0ff button but that is it.
I tried searching but my google-fu is weak.
Are there common issues that come up concerning cruise control? Common things to check before really tearing into it?
NC_John
North Carolina
Months late but am just browsing around and saw this. Check/change your brake pedal switch. Its probably stuck, wore out, broken.... Cheap fix and you should be good again.
dbbd1
Whole different animal but that was the problem (brake switch at the pedal) on my '99 Dodge Ram too.
David Smith
Savannah, GA
I am having a similar issue, but the light on my steering wheel does not even come on...any ideas?
adventurenali92
Big Bear Lake, ca
If you have a brake light bulb burnt out in either of your tail lights, cruise control will not work. Safety feature that gm built into these. At least that’s how it is on my 2006. Check your tail lights first. Cheap easy solution if that fixes it haha.
Tahoe14
Central Fl
Your owners manual should show you which fuse. If you don't have a hard copy look online for the PDF version. Good luck.
Could be the module on the steering wheel, clockspring, etc. If you try to operate it and it does not work the BCM should set an internal code that you can pull with your Tech2. Didn't you also have something going on with the steering wheel position sensor?
David Smith
Savannah, GA
I never saw any codes come up when I had the scanner hooked up. The airbag was deployed, so maybe clockspring? I will be checking fuses and stuff like that first.
Well, it could be the switch itself on the steering wheel. I'm sure you have access to them in the scrap yard to test/swap out.
Malakas
