Can a 05 denali throttle body fit my 01 denali?
LinuxMint
Georgia
I'm pretty sure, as long as they're both from the 6.0 liter (which they'd had to be if they're both Denali). The differences between the pre and post-03 engines are minor and mostly internal.
FreshLikeOprah
You have a different style DBW tb than the 03+ trucks. It's the same style that came on vettes, but the throttle body motor is on the opposite side. You can use this harness with LS2 tb, which is 90mm vs stock 78mm.
http://texas-speed.com/p-1195-harness-adapter-for-ls2-throttle-body-on-ls1-vehicle.aspx
The throttle body is 4 bolt vs 3bolt so it's not a direct swap, you would gain the most from doing a NNBS or TBSS intake and 90mm tb from ls2. Gain about 10-20rwhp. Even more if you do cam and stuff.
But no point in going from a 01 to 05 tb. Same size.
thomase1269
