Cam retard setting
firedog
checked my distributor today, been skipping alot, found gear almost worn completely away. Cam retard was at 12 degrees. Replaced distributor retard was at 38 degrees. Moved around til i got it to 2 degrees. once at 2 degrees the truck would barely idle and when i tried to idle it up it would pop and backfire. WTF?????????
SunlitComet
OBS Jedi-Do Good
unknown at this time.
You screwed something up. Take the dizzy out. Zero the engine to tdc on #1 one in firing position. and reinstall using the marks on dizzy body to ensure proper alignment when seated. If done properly and carefully you should be within 1 degree of a scanner zeroed engine with out using a scanner.
F
firedog
what are the chances of a bad timing chain???? 168,000 and never replaced to my knowledge?
F
firedog
it was just a thought, thanks for the reply will probably be replacing this weekend
SunlitComet
OBS Jedi-Do Good
never seen a maintenance manual say replace a timing chain every 100,000 miles.
---------- Post added at 08:57 PM ---------- Previous post was at 08:57 PM ----------
actually at any mileage.
rick9667
