Cam postion Sensor
Gary H
Good Day to All:
looking for info on the following, 2009 Tahoe Gen 3, 5.3 Vin 0 Cam position sensor Wiring Diagram. The connector near the Timming chain cover was destroyed. I am looking for the color code and pin positions. It does have a harness extension to sensor it also blew the Engine control Fuse
Moderator
People's Republic of Colorado
Go here:
https://charm.li/Chevrolet/2009/Tahoe 2WD V8-5.3L/Repair and Diagnosis/Diagrams/Electrical Diagrams/Powertrain Management/System Diagram/
but double-check that the vehicle info is correct. Save that site for future reference.
On the link above the cam position sensor is shown on the second diagram. See if that helps you any.
And connector X112 is on this diagram: https://charm.li/Chevrolet/2009/Tahoe 2WD V8-5.3L/Repair and Diagnosis/Locations/Connector Locations/Connectors By Number/X100 - X199/X112/
rdezs
That short section of harnesses readily available, it goes on the front of the timing cover. The cam sensor plugs into it at one end, and into the harness down below harmonic balancer. Shouldn't be any need to splice anything
rdezs
vsaravia
