Blend Door Actuator - where is it?
bpollard
Hello,
2009 Yukon Denali, NON-manual temp controls, and the driver's side only blows hot air. Dealer wants $680 to replace the "Driver Temp Door Actuator" which I believe to be the "blend door actuator". Sounds like an easy job, and there is lots of info about it for other model cars (generally pre 2007). Does anyone know where this actuator is under the dash for a 2009 Yukon (non-manual temp controls)? Dealer won't give me a part number and rockauto is hard to figure out a part number for this particular part. Any help you have would be much appreciated!
ezdaar
Chat Troll
Redneck central, Aka Houston
There is two of them, one up behind radio and other to left and above passenger feet.
Remove them both. write down model numbers. re install them.
EBAY or rock auto for replacements. tell stealership to get lost. do it yourself.
B
bpollard
thank you for the information. do you know which one controls the driver side and which does the passenger side? I was hoping to just replace the broken one as I will be selling the car soon....
Lastly, does the radio need to be pulled to get to that one? The radio (I have touch screen navigation) is really high up in the dash, no?
thanks for the response.
ezdaar
Chat Troll
unplug the one by passenger feets. see if any controls stop working. if they do then its the one behind radio.
If nothing chages, thats the one.
B
bpollard
if it is the one behind the radio, is it as difficult as it sounds to reach it?
B
bpollard
If you were a betting man, would you guess it is the passenger feet one or the radio one?
Erik G
Houstone Town
If you shut it off, and re-start it, does the AC work again? My Sierra did this once - right before it got stolen
DavisJr
I am having this issue with a 2009 Yukon Denali.. I have hot air blowing out of the driver's side air ducts when the A/C is on. As stated above, I can not find any additional information about this. Do anyone have any information where I can find these two actuator and some information on steps to change them out?
Any help would be appreciated....
black1970
It's the one on pass. Foot. Auto Zone has it. Lifetime guarantee. Costs about 20 dollars. Not too hard to install.
t.stimpson
my 09 denali is blowing cold a/c but only on the floor. It will not come out any other vents no matter what the setting is. Anyone know whats causing this?
JeffK
