Bent Rim or pebbles in tire tread
BG1988
at about 70mph it starts vibrating and worsens at 75mph-80mph
i noticed the rear driver side rim is slightly bent at the lip :(
the tire is not losing air
but there is a lot pebbles in the tire tread(this could also throw the balance off ?) other wise it drives fine below 70mph
they don't call them BridgeStone tires for nothing
as they collect stones and bridges the gap in the tread
It drives true and straight and no abnormal wear
Big Mama
Virginia
Usually rocks won’t be the cause but pluck them out and see. Maybe you found a new fix. If the bend is bad enough you’d feel it all the time. My guess is a weight came off. Rebalance all 4 cheap insurance
PG01
Up here to the right
Normally a vibration over speed is the balance, as Steven stated.
Go have them balanced and rotated and take a ride.
B
BG1988
they said they would check it out for free if it need to be balanced then it's $7 a tire..
The ride does feel smoother after going threw and removing all the pebbles embed in the tread...
pulled out about 1/4th of a pound of rocks total from all 4 tires
my tires are an Amateur geologist rock collector
NERD!!! :emotions33:
Big Jim
