BB tuned 6.2 trucks??????
MACHO
Seattle, WA
Stumble out of gear? Could you elaborate? If you're talking about a clumsy downshift I didn't really experience that but I know the trans does take a period to "learn" the tune and Justin said to send it back with a log if I had any issues.
I depends on throttle input. on My first tune they held 1-2 for quite a while and then I asked Justin for a modified tune and which split the difference between the original tune and the stock tune. Now it's perfect.
08grey
1st and 2nd stumbles into the next gear slopy like in the 20mph - 30 mph range.
i have run it 200+ miles to let it learn but it just gets worse.
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
Mention that to Justin, so he can look for it in the datalogs. Did you send him a new log?
Sent from a jelly bean.
THE YETI
Director of Operations
South FL
man I dunno... my truck runs like a pissed off gorilla with my BBT. Enough torque in this 6.2 to break loose my heavy ass 22s and 35s. And I consider my tune a little on the mild side.
This has to be about my 6th tune I've had Justin do with my trucks since 06.. always spot on.
Speck
Olympia, WA
I hope you get the bugs worked out. I'm hoping to go with this tune someday as well, so I'm definitely taking notes on things. :birgits_tiredcoffee
Administrator
Some off topic posts have been deleted from this thread. Let's work on keeping the thread on topic.
Thank you :Handshake:
Brock
Senior Member
NC
Justin did my tune when he was in my area last year. We made several test runs & he tweeked my tune after each run. A "sport tune was not mentioned" I just let him set it up as he saw fit for more HP & ++. Justin did smooth out shift points + increase RPM limit. When I use the manual shift RPM will go to about 5900 before the computer shuts the fuel off. Stock was about 5100-5200.
Over all very happy with BBP & I had the best Superchips made ($600) & it SUCKED!!! The shift points hit so hard something was bound to break eventually. You gotta use premium-MPG increased a few (17 &12).
VEry important!! Justin had to completely remove my previously installed Superchips tune, which took about 1/2 hour.
Sold that SC on CL for $200.
08grey
Yes that was the issue I had as well my previous superchip tune left things in there even after flashed back to stock. Justin worked that out with me and we have been dialing it in.
losloho02
