AWD Problem in Caddy EXT
beav626
Pretty Girls in your city for night
Usa
Enjoying the Snopocolypse 2011 I was trying my truck in the snow.
03 Escalade EXT 108k miles
She did well untill i noticed the back end kick out. Stabilitrac cought me but I thought AWD trucks dont do that.
So I went to a paking lot with some store fronts to see for myself.
No front wheel spin just rear wheel.
Next I took her home and got all 4 wheels off the ground.
No front wheel spin.
I put her in Neutral and spun the front wheels by hand they would spin freely no engaging the other front wheel.
Then I put it in Drie and shut her off.
Front wheels wont spin...
Start her up and put it in Drive and I have front wheel spin.
What am I missing here.
Rivieraracing
So how does it drive in the snow, does it feel like a rear wheel 2WD truck or does it drive good like it's in 4WD?
B
beav626
Usa
It drives like a 7000 lb 2wd truck with traction control.
I believe I was able to engage front wheels by reving it in n and to d.
B
beav626
Usa
spoke to a friend today and he explained something to me.
The AWD system only allows 2 wheels to spin at once and it6s the 2 easiets wheels to spin.
if the back wheels are stuck then the front wheels will spin. If the front wheels are stuck then the back wheels will spin.
Can anyone confirm this?
Rivieraracing
It doesn't sound like what my AWD denali does, and it also doesn't drive like a 2WD truck in the snow either!! Sounds like something indeed is wrong, I wish I could help ya!
Administrator
Have you had a chance to get it scanned for any error codes that might pop up? If a sensor is bad for the AWD I'd think it'd throw a code of some sort.
Rivieraracing
Also, have you read up on your owners manual? It should tell you pretty much how the AWD works on your truck, might give you some insight on your question!
B
beav626
Usa
Here is what I found....
Here's some general info about the AWD system from the service manual.
Transfer Case Description and Operation
The NVG 149 RPO NP3 is a single speed, single mode transfer case. The mode is full-time all wheel drive. It has a planetary differential gear set that splits the torque, normally 38 percent to the front wheels and 62 percent to the rear wheels.
The NVG 149 utilizes magnesium housings. Proper fasteners, brackets, and fill/drain plugs must be used to prevent galvanic corrosion. The planetary differential uses the carrier (6) as the input. The annulus gear (4) connects to the rear output shaft (5) and rear wheels. The sun gear (3) connects to the front output shaft (7) and front wheels through the chain (8) and sprockets. The viscous coupling (2) consists of a sealed housing filled with a high viscosity silicone fluid and thin steel plates alternately splined to the inner and outer drum. The inner drum is connected to the input shaft (1), and the outer drum to the sun gear (3). Whenever there is a speed difference between the front and rear wheels, the inner and outer plates of the viscous coupling spin relative to each other and the silicone fluid provides resistance. The resistance was tuned to be high enough to bias power quickly to the wheels with traction, and low enough to prevent binding in a tight turn on dry surfaces. This is the most common way the viscous coupling is activated, the shear mode. If the speed difference is high, the coupling can lock or hump. This "hump" occurs when the heat generated, expands the fluid inside the housing, changing the fluid dynamics between the plates. This results in pressure between the plates, forcing them into contact with each other, similar to a clutch pack. In the hump mode, the coupling can bias torque 100 percent to one axle, if required. Situations requiring this are extreme such as backing up a steep gravel grade or climbing over off-road obstacles. The viscous coupling is not serviceable; it must be replaced if defective. This is because each viscous coupling is calibrated for optimum vehicle performance for both the shear and hump modes. If the viscous coupling is in the "hump" mode too long, severe damage will occur. To prevent damage to the viscous coupling, DO NOT:
Tow with only two wheels down
Drive without one propshaft
Drive with a "donut" spare tire for an extended period of time
Power Flow - No Wheels Slip
During normal operation, 100 percent torque is delivered to the input shaft (1) from the transmission. The torque is split to 62 percent to the rear output shaft (2) and 38 percent to the front output shaft (3), by the planetary differential. Because there is not a loss in traction or slip in the front or rear wheels, the viscous coupling is locked in place and there is no "shear" mode or "hump" mode involved.
Power Flow - Front Wheels Slip
When traction is lost at the front wheels, the viscous coupling works in conjunction with the differential to bias the torque more to the rear wheels. The rear torque goes higher than the 62 percent, and up to 100 percent torque to the rear output shaft (2). The torque at the front output shaft (3) is lowered from the 38 percent, to as low as 0 percent torque.
Power Flow - Rear Wheels Slip
When traction is lost at the rear wheels, the torque is biased to the front wheels. The torque to the front output shaft (3) goes higher from the 38 percent, up to 100 percent torque. The torque at the rear output shaft (2) is lowered from the 62 percent, to as low as 0 percent torque.
Customers may have concern that the transfer case is not operating properly because one set of tires spun for a brief period. It is normal for one set of tires to spin until the viscous coupling engages.
Turning off the traction control switch, if equipped, enhances the function of the viscous coupling. The viscous coupling, as described above, engages by heat. Allowing one set of tires to spin or slip for a brief period will generate heat in the viscous coupling. The engine speed should be kept at a constant speed during the brief spin of the tires. Pulsating the engine speed or hard acceleration will not allow the viscous coupling to operate properly.
mtglick
