I need to know how to do it and where to mount ballast? What size is the bulb for 2001 Tahoe?
Not sure what the purpose would be, but one of the biggest issues I foresee is that unless you want to quickly fry what I imagine will be cheap ballasts, you're going to need to run something to delay ignition ... otherwise they will fire up every time you switch in and out of 'park' on your transmission.
Running a self contained auxiliary (halogen) backup lamp is not only going to be easier, but also a more reliable and more effective way to achieve additional backup lighting.
Let me guess, you can't see through your tint?
---------- Post added at 07:18 PM ---------- Previous post was at 07:12 PM ----------
Not endorsing the practice but here, this is the type of kit you'd need:
http://www.aliexpress.com/product-f...amp-fog-light-and-stop-light-wholesalers.html
And some info:
http://www.hidplanet.com/forums/sho...-light-options&p=480807&viewfull=1#post480807
Then also you may want to strip some of the tint off the reverse lights, hell they may be to dark for your brake lights also, well be careful because if you get rear ended, you will be at fault.
These may be better for you. Someone on here has a posting of these and they are very bright. Then also you may want to strip some of the tint off the reverse lights, hell they may be to dark for your brake lights also, well be careful because if you get rear ended, you will be at fault.
http://store.ijdmtoy.com/Extreme-Super-Bright-High-Power-LED-p/3157-led-sku313.htm
Sent from my iPhone 4s using Tapatalk.
