Any problems with 01-04 Yukon Denali?
VIPNiSS
Any problems with 01-04 Yukon or Tahoe?
Hi everyone, I am looking at buying one as a secondary car and also to pull my 5000 llb boat. Also looking at Tahoe's as well. I am guessing both are the same?
Are there any issues with this model and years I should look out for when purchasing?
Thx in advance!
chauncey0337
MLT, WA
Welcome Tommy. Yes, yukon and tahoes are pretty much the same besides some cometics. Major difference between the 00-02 and the 03-06 models is that the 03-06 has upgraded electrical systems and interior.
Look out for tranny issues.
V
VIPNiSS
Oh the joys of tranny issues.. lol.. you can test drive it and be fine and then a couple of months later your replacing the tranny..
V
VIPNiSS
I suppose there is no real way of testing the tranny is there?
alc5m
with 03+ one of the biggest issues is the stepper motors in the gauge cluster, they go bad and they're soldered in so its a ***** to replace
and i think 05+ has the fuel filter as a sealed unit inside of the tank, so its more of a pain to replace cause i think you may need a new fuel pump with it, but i'm not 100% on that
coolchuck
maybe Escalade bound?
DC Suburbs
You mentioned Denali in the title. Biggest difference is Denali is full-time AWD, not selectable 2 or 4WD like other models. Not sure if that matters for towing a boat though.
Jewel or Jalopy
Portland, ORE
Denali will also have autoride, which isn't always the greatest if you have a WD hitch setup. More gadgets on Denalis. I also couldn't find one where the dash and console paint wasn't chipped to hell.
Denali will also have the 6.0 lifer engine. More power but more fuel. We tow a 60000 lb trailer with out 5.3 and it does fine.
Good luck with the search.
Sent from my Kindle Fire using Tapatalk 2
livingez_123
Sandy, OR
front diff's on the Denali's seem to last about 100k then it's a $460 rebuild...put it back in and keep driving. also the chain in the transfer case gets some slop in it and can make noise at low speeds.
johnsonwillie199
